- Sep 5, 2014
- 5,170
IIRC, Briggs was ordered to pay some money to owners, who bought the machines in the suit..If my memory is any good, those where the engines which got Briggs in trouble and started the questionable hp lawsuits.
That's interesting. Side note, back in the late 1960's, Pontiac did the very same thing to the Firebird's 4 barrel carbs so the GTO with the same engine/transmission as the Firebird, would be a bit faster. They did it with the linkage to the rear barrels.Kohler did the same thing with the CH18-20-22 engines. The 18 had a screw next to the throttle butterfly lever that limited it to only opening halfway. the 20 had the screw removed which allowed full throttle plate movement, and then the 22 added spark advance smart spark.
I remember that.....Back in the 80's they were putting BOP engines in chevy cars and then they put chevy engines in BOP cars.
Little more to it than just the carb linkage. 400CI Pontiac engines 1967 and up used the same block, but offered some different HP ratings for GTO, Firebirds and other models - such as HO and Ram Air type optional engines. All had 4 barrel Quadrajet carbs but used higher performance heads, intake manifolds, exhaust manifolds, and cam shafts, etc. May all look the same on the outside, but they are different.That's interesting. Side note, back in the late 1960's, Pontiac did the very same thing to the Firebird's 4 barrel carbs so the GTO with the same engine/transmission as the Firebird, would be a bit faster. They did it with the linkage to the rear barrels.
Thanks Rivets- Good advice.Anyone who attends punching jet nowadays should be prepared to purchase a new jet or carb before attempting to do this. Voice of experience.
