Got a model name and serial number? I can look up the specs for you.
You'll need a tachometer to measure engine speed, or have a shop check it. The throttle and governor linkage can be adjusted if the engine speed is too low.
Caveat: I work for Honda, but the preceding was my opinion alone.
