New to the forum, but I am having a wonderful issue with my Honda self propelled lawn mower.
Apologizes if this has been talked about a lot, but I couldn't find anything using the search function for the forum.
Lawnmower is about 2 years old. The pull cord seemed to slip when starting, to the point where the pawls do not rotate the flywheel. When I can get the flywheel to turn, the mower starts and runs fine.
It has the GCV160 engine.
Purchased a new pull start assembly from shop in town for $8 (figured it was easier than messing with the existing plastic assembly. Went in easy. Pawls engage, however, after one start... same problem.
Open removing the cover and inspecting the flywheel... the fan assembly bolted to the flywheel (and where the starter engages) is made out of plastic. It seems, even when bolted down with a washer and 3/4" nut, to move when I turn it independent of the flywheel--> so when the starter is engaged, the fan assembly is the only thing turning... slipping against the flywheel.
I have removed the fan by removing the 3/4" nut (requiring a impact wrench and a block to keep the blade from moving along with the flywheel), cleaned it, then reinstalled it, torquing the nut down. Problem is still there...
Is this a common issue on these mowers with this engine? I think these fans used to be made out of metal...? Do i just have a "bad" fan, so replacing this should fix the problem?
Thanks in advance for your time in helping me with this problem.
Jason... in Texas.
Jason... in Texas.
