robert@honda
Re: Honda HRX217HYA - Pushing throttle lever further than "FAST' Indent position?
While it is not an elegant method, it is rarely needed but is effective. Some Honda dealer techs tell me it is "better" than previous spring-loaded, set-screw-type designs, as it won't change as easily (no screws to come loose), and deters a casual customer from fiddling with the settings. I know the emissions rule groups have some regulations that require engine manufacturers to discourage what is seen as "tampering" with parts of the engine that change the emissions profile, and max speed (and idle) adjustments are probably in that group.
The bending of the arm is the part I don't like!
