Honda HRX217 Has Two Woodruff Slots
pross21419@comcast.net
Hello, I have a Honda HRX217. I replaced the clutch bearing. Upon reassembly I noticed that the output shaft from the crankshaft has two woodruff key slots. One is apparently for the drive pulley and the other is for the drive disk. The diagram shows two slots but only one woodruff key. Since I only removed one should I buy another and use two?
Sixth post down shows diagram:
https://www.lawnmowerforum.com/showthread.php/36263-Honda-stripped-bolt-on-blade
No need for two, that crank is used on multiple setups, hence two slots.
Catherine
LawnWorld Support
:welcome:
Welcome to the forum!
I'm going to move this thread over to our Honda section.
