[email protected]
Hello, I have a Honda HRX217. I replaced the clutch bearing. Upon reassembly I noticed that the output shaft from the crankshaft has two woodruff key slots. One is apparently for the drive pulley and the other is for the drive disk. The diagram shows two slots but only one woodruff key. Since I only removed one should I buy another and use two?
Sixth post down shows diagram:
https://www.lawnmowerforum.com/showthread.php/36263-Honda-stripped-bolt-on-blade
