Chris Parman
did anyone find out how to get the belt past the guard bracketHello Chris, Did you find a solution to removing the belt from the transmission pulley.
Remove the pulley by removing the nut. I hold the pulley by squeezing the belt tight and using an impact wrench. You can then install new belt and tighten the nut.
