When you guys lube the new bushings, make sure you use something safe for rubber/plastic. If you use the same grease you put on the pinion gear you're probably asking for trouble.
I used DuPont Teflon Non-Stick Dry-Film Lubricant. Its supposed to lube and repel dirt/grime. The one bearing has a rubber seal on one side that is supposed to help keep gunk out. However if you use grease that isn't compatible with rubber/plastic, that seal will break down and let gunk in and will freeze the bushing on the axle.
I replaced my height adjusters and got new bushings this summer and so far its working perfectly. I'll update after the cutting season next year.
