(bertsmobile1 ).
Thx for reply. It does seem to me float issue but when I take bowl off it’s approx 2/3 full. So seems should be where it needs to b. Jets oblong May be good.
What caused it all was it was running little weak then I ran it out of gas trying to finish up last bit of yard. I thought running out of gas may have god something in carb, took apart couple times before seeing o-ring on jet was bad. I ran out of thoughts with carb why I wanted to check key.
