SouthWestern
- Oct 6, 2025
- 1
- 5
A non-starter this morning, (after some months unused) and after fresh fuel and a quick carb clean:
The engine starts smoothly, and seems to run great.
After a minute or two, it starts to cough, splutter and backfire, but mostly doesn't stall.
Then after a few seconds (10? 20?) it then bursts back into life and seems to run fine for a short while before repeating the process.
Fuel seems to be filling the carb, I tried removing the fuel filter as a test - no difference.
I also tried briefly without the air filter, maybe a little worse but not much different.
It does seem to run smoothly at low revs.
Any pointers to what might be wrong?
Thanks!
Thanks!
