Hi All,
New member here trying to fix my Honda Mower (Model/Serial Above)
It will start immediately with starter fluid. I only did it two times as I don't want to damage anything.
Fuel Line is fine (stop cock stops flow and Starts flow)
Bowl seems clean (it is the cone shaped bowl)
Float seems fine as it closes and opens when up and down
Removed Carb and thoroughly cleaned it as best I could.
Same problem when I replaced it.
Any suggestions are appreciated.
Thank You,
Jeff
Thank You,
Jeff
