hppants
- May 2, 2020
- Threads
- 1
- 7
Greetings:
(I searched before I posted)
Honda GCV160 motor won't start. I'm not a mechanical genius, but I've "turned wrenches" for a long time. This is what I've done/know:
1. Won't run on carb fluid or starting fluid.
2. Cleaned carb thoroughly (trust me, that ain't it)
3. has what I consider to be good strong fire at spark plug.
4. Motor has no compression using tester.
5. Pulled cam cover, ZERO valve clearance on exhaust valve (compression release working?) About 0.006" on intake.
6. Can't find timing marks or instructions on how to check time, check flywheel key.
Motor is on a 3 year old pressure washer that otherwise is perfect for me. I'd appreciate any advice you can offer.
