Repairing this Self perpelled Craftsman with a Honda Motor for a neighbor. It would run a few seconds and die. Figured it was the carburetor so I took it off and sure enough it was all corroded up. So I gave it a good cleaning and when I was putting the carb back on found the right mounting bolt would not snug up. I'm very familiar with not tightening up these bolt too tight cause I know they can easily be stripped out. So I snugged it up best I could with the bolt slipping in it's tightest position. The mower cranked up and ran but I could tell it wasn't running up to full RPM/potential. I figure it's leaking air in around that un-tight bolt.
My neighbor said it quit running at the end of season last year and he took the carb off and installed it back on but it still wouldn't run. He is not a mechanic! I figure that's when the stripping out occurred.
I haven't got any re-threading tools, so what do I need to tell him he needs to do to correct this??? Thanks, Bob
