primerbulb120
- Nov 3, 2014
- 43
- 1,315
I think you need to try a real spark tester. If the paperclip is grounded against the valve cover, it isn't going to spark.
Thanks, Iron.
I didn't see any contacts in the ignition circuit. I think the position of the magnet on the flywheel determines the timing of the spark. I will have to check the coil for continuity this weekend.
The term "wet and dry" is used here too, as well as in NZ where I was living for a few years.
You bewdy... well done!:cloud9:Thanks for all your help and suggestions.
Got it running yesterday.
Yeup...can get a bit "rank" ...as they sayAfter letting it all dry out and re-assembling it, the generator started up after a few pulls and ran until the tank was dry. I now know what IlEngine was referring to when he said "it will end your mosquito problems for a few minutes." I had to stand upwind until all the oil burnt off![]()
I think in the future, I will drop the carb float bowl and the fuel valve bowl and blow all the fuel out of the carb before putting the generator into storage.
