Hey all, before anyone says it Yes I know it is dangerous but I am the only one around when it gets used and I know I am not getting in front of it while it is running. Got the mower for $20s and found out that it ran. :smile: Then I cut the front up a bit so that the blade could meet the heavy weeds and brush first before the deck pushed them over. So far I have used it to trim down a bunch of over grown weeds and heavy grass on my farm. The area I used it is too rough and step for the rider to get into so I built this. Added the extra paint as additional warning incase someone else was near by but I keep a sharp eye out when I am using it. It has cut down 1 to 1 1/2 inch diameter saplings and thick stalked bull nettles. Needs a bit more work on the carb but I am happy with it.
View attachment 23142 View attachment 23143
Tom
No need for welding.
If you use 1" x 1" angle or bigger then all you need to do is drill a hole then file it square and bolt it together with coach bolts.
Heck you could even use old blade mounting bolts just file out the holes to fit the ends so the bolt is captive & can not turn
Fwiw had something similar to this I customized a craftsman field trimmer with a b&s 6.0 when it was given to me the mounts for the trimmer line had been worn off (many many hours) so I removed the trimmer head, purchased a mower blade I found suitable, marked and drilled 2 mounting holes and mounted it with 2 grade 8 bolts and some loctite.the front is left open to tackle up to 2.5 in. Sapplings.As you said it is dangerous but if you're the only one around it doesn't really matter![]()
