Hole in Tire
Tire Hole
There is a small hole in my front tire of my rear engine riding mower about the width of a pencil. How do I fix this?
If it is a really big hole you might need a tractor plug.
Same stuff, just bigger
And use mower plugs not car ones
Most car ones have a heat activated glue and mower tyres never get hot enough for it to work so a week latter it is flat again.
yep, i've been running with a plugged tire in my cub for about 8 years. never has leaked down.
Plugging the tire may seem cheesy but in most cases will outlast the lawnmower, And if the tire get unpluggable then pull the plugs and put a tube in it unless the tire is just coming apart and I mean separating.
