Hi
dakotanut
New here. Having a problem with my Scotts mower and my MTD riding lawnmower. Sure hope I can get some answers to the riding lawnmower. The push mower is easy to fix. I'm trying to find a service/repair manual for the MTD. Not sure if it's fuel issues or if its with the charging system. I posted about it under MTD. I have vast mechanical knowledge just get stumped sometimes.
When looking for manuals on line, make sure that when googling, you type in the name and model number of your unit. If you have no luck post them here and someone should be able to help you.
dakotanut
Where do I post for such things here? I'm having no luck finding the manual via google, bing, or safari. Just my luck. LOL.
Carscw
Go to MTDPARTS.com
Sent from my iPhone using LMF
dakotanut
MTD Yard Machine
18 HP 42"
Model #: 13AQ670G372
4376273
Has a Briggs and Stratton 18 HP Twin II
Model #: 42A707
Type: 2238E1
Code: 9801225B
Thanks for the help locating a manual. I don't have a job atm. I was hoping to find one I could look in online to see pics of things.
dakotanut
I found it at a small engine forum. I was ecstatic about it to say the least. I've done many of the tests that are in it. Still have the same problem with the tractor. I will use those also for parts look up. Thanks.
