- Feb 19, 2020
- 80
- 10,322
Boy is HFT going downhill from poor quality to bad quality. I recently brought two 1/2" torque with plans of converting one to do left torque. Out of the box either had scales that line properly. On one you got a 6 in aligned and the other a 5. So basically you don't if even getting the right at a setting of zero on the 20 ft lbs. On top the one that as a back up is so far off it is not even funny. I was comparing it to my accurate 3/8" at 41 ft/lbs today. The 1/2 would not even click at a setting of 20 ft/lbs. So out the door it goes. I buying a digital adapter version that can do both left and right torques.
On top of that the ratchet wrenches I brought last year had chrome already flaking off. Air grease gun I brought three years has also failed.
Bye Bye HFT.
Bye Bye HFT.
