reynoldston
- May 23, 2011
- 5,705
I don't know then? Your points are opening to .020, nothing wrong there. New magneto (coil) did you install it upside down? what is the coils air gap? Did you touch the point contacts with oil on your hands or just touch them? Are the points closing all the way and making good contact? Is the kill wire shorting out? Did you crack the new spark plug? Is the plug wire end on good to the plug and wire? Re check all your work because you are missing or doing something wrong.
