Hazmat
- Jun 7, 2020
- Threads
- 1
- 4
Newbie here. I need some help figuring something out. I bought a new to me 2015 husqvarna mz52. My first z turn. I had it about 2 months or so now. The problem that I am having with it is, it will not crank,start,click or nothing after I running it for 30min to a hr and cut it off. I can let it set a little and it will start. When it won't start I just start it with a screwdriver. I already replaced the ignition swith,the starter solenoid,and the guy I bought it from said he just changed the PTO switch last year. But still thinking it might be the pto switch. I also noticed to today that the wire that goes to the starter from the solenoid has a little rust on it. I thought I cleaned it when I changed out the solenoid. Going to clean it again this week some time. But any info or advice on what else to check would be appreciated. Thanks
