Travis97
- Jun 11, 2023
- Threads
- 1
- 1
I just had my John Deere 106 (2006) riding mower took to the shop because it had a blown gasket. The shop replaced gasket, the cam, crankcase gasket, and oil seal replaced. When I started it, it runs but it sounds like plastic is ticking inside the motor. The knocking gets faster as the engine runs higher. I tried to give it a test run to see if it would work itself out but after about ten minutes I could feel the mower struggling to push itself slightly and the motor started to overheat. (Of course I shut it off before any damage could be done )
Does anyone know if this is something simple or did this shop mess something up?
