PTmowerMech
- Apr 16, 2018
- 396
- 3,018
The ID plate isn't under the gas tank, so other than the tag in the pic, I can't find it. Where do they put them on these old tecumseh's?
Also, and just as important, the engine has compression. Except it's all going out the carburetor. So I'm guessing it has a valve stuck? Is that right? I can't hold my thumb over the carb tight enough to get a compression reading.
