Help with cub xt1 instantly blowing fuse
James844
It is running with a new strator. I had both strator and regulator here and tried them with the same result with is confusing before I got on the forum. Went back to the oem parts since there was no change. I did question if I had the right strator because all the poles have windings where the oem have 6 poles without several windings. But I double check the part numbers and everything checked out so I reinstalled it and everything good so far. The only thing I can figure I did different is bend the metal support further up to make sure no contact between it and engine. I dont know if thar was an issue the first time or not but I was checking everything. Thanks for the fast responses and help.
PTmowerMech
Sorry to bring this back from the dead. But how can a 20A fuse blow, just by plugging it in (key off). I can see a bad regulator being bad, (not regulating the amps). But the stator? I don't get that.
