you tube mechanic
- May 1, 2020
- 27
Ok, so the saga continues with a new problem. New carburetor has arrived and installed on 5/12/20, changed spark plug again also due to the other one looked fouled from the fuel flooding issue. Tractor started right up with a little choke input. run great, drove it down the street 100 yds or so and back. no issues, continued this process for 3 more days with no issues. Went to deliver mower to owner, started up, drove it over to her house about 1/4 mile away, just as I was turning on her street it sputtered a little and popped out a small cloud of white smoke from the exhaust, then pulling in driveway it sputtered like it was dying and produced a massive white smoke cloud that I couldn't see thru. Both times engine recovered and continued to run. Shut it off and we talked awhile, started it several times in her presence and now it backfires nearly every time but starts and runs if I understand the function of the shutoff solenoid it should not backfire. I asked her to mow with it for the next week or so and let me know what it is doing. I am at a loss of what else could be causing this new problem. I made no adjustments on the new carb, figured it was tested before they sent it. Please advise if you can. (I did check the solenoid before installing new carb with a 9v battery, I could hear it actuating). Thanks for any and all help.
