Help starting
Red Good
When you say the motor turns can you see the flywheel turning , the other is my starter was acting very similar , turning not fast enough to engage and the magnet had come loose inside the starter . Repaired it and all good now . Good luck .
Pdivens
That's exactly what it sounds like. Guess I'll tear it apart. The flywheel spins about two rotations then sounds like it dies.
Red Good
If you look in yellow pages find someone who rebuilds starters and alternators they should be able to help . And they see lots of this sort of thing .
Mark the flywheel with a paint pen and then crank the engine and see if the flywheel stops in the same spot every time.
If that is the case then either your starter is worn and can not overcome engine load or the engine load it too high due to lack of decompression or worn cams, bent pushrods etc
