- Sep 24, 2017
- 277
- 6,743
The carburetor is behind the air filter on the right side of the motor.
You need a 5/16 and 3/8 socket to remove it.
taking float bowl off worked ... not sure what was in there... water or gas or oil ... but engine is running fine.Water in carb or float level is off. Pull float bowl from bottom of carb and if fuel is pure, note level of fuel. It may be too low or too high.
yes... that was something I had done before to try and diagnose.Have you cleaned out the fuel tank,And replaced old gas with fresh?
