There should also be a button in the area of the key switch that you also have to push to go in reverse. the other thing to check is to make sure the headlights work. For some reason they wired the reverse safety system through the headlight circuit.
Yes I just rewired the headlights haha, the hood cut into wires...... The spring has arrived going to install it later . I will update progress once complete.
Thanks again for your help !!!
