cruzenmike
- Feb 10, 2017
- 59
- 858
awesome post, thank you. I setup an appointment to get a demo. However, I would want the rear discharge and the whole kit im lookin at like 14 grand.
Ferris 400s is my current favorite.
You think the ferris will need replacing 3 times over the next 25 years?
The problem I have - these used mowers were beat to **** for 1000 hours. That's 20 years of use at my rate. Logic tells me its a bad idea....
Buying used commercial has never given me the warm fuzzy feeling. To put it into perspective regarding high end residential/low end commercial, I had an Exmark that cost around $6,000 new in 2006. I estimate that over it's entire life about $2000 was put into it for parts and routine servicing. At the point at which I sold it this spring I am quite confident that it would give at least a couple more years without needing anything simply based on what I had replaced. So at that point $8,000 for approximately 15 years of use. That is still over $500 a year for the cost of ownership not including the cost of gas to run it.
As with most equipment you just don't know what will happen long term but one thing is for certain that steel doesn't break as easily as plastic, routine service helps your odds of long life and buying something that is made for what you intend to use it for will ensure that your expectations are met.
As for your question about the Radius E, it does have a deeper deck than the MX4250 which will help move more grass out from underneath the deck resulting is a better cut. As for the difference in transmissions between the two, as a homeowner you may not notice a difference in the ground speed but as stated the serviceable transmissions will last longer if properly serviced.
Now on to the Ferris. The 400s is a good machine for the price. If you are contemplating the two engine options consider that the Kawasaki is more money while offering less power but it a bit quieter. I like that the 400s is quite compact and has a nice heavy duty build and deep deck. The discharge chute is wide and open allowing for grass to exit the deck. I do not know about bagger options or mulch performance but for side discharge it will work well. Also the speed is up to 8.5mph I believe which will certainly cut your mowing time in half.
