Flintstone
- May 5, 2013
- 1
- 3
A year ago, I bought a 1996 Agway (MTD) 42", 14.5 hp B&S for a new 5 acre property. The land, once beautifully landscaped, had been quite neglected. I put this poor, old mower through hell hitting rocks. One time, I hit a big rock and one of the belt guards actually FLEW off. Ever since that incident, every time I DISENGAGE the blades, it makes a God awful whining/screaming sound. This whining/screaming happened only as the blades slowed. Once fully stopped, the sound went away. It creates no sound when the blades are reingaged.
So, this spring I decided the belt had stretched and needed to be replaced. Today, I replaced it. While I had the deck off, I also replaced the blades.
The sound still occurs. But it's worse. It makes a whining/screaming sound constantly, however less severe, when the blades are DISENGAGED - and only disengaged. It's as if nothing is wrong when the blades are engaged.
Bottom line: I have a moderate whining/screaming sound constantly when the blades are disengaged. I have a severe whining/screaming when disengaging the blades till they wind down and then it settles in to it's moderate whining/screaming. When the blades are engaged, you wouldn't know anything was wrong. Belt is new. Blades are new.
On what should I focus next?
Thanks!
Thanks!
