The power rating on the Husqvarna is completely wrong. That is the same Honda GCV160 you find on all the residential models.. It has 6.9lb-ft of torque. The 4.4 is the net hp rating for that engine.
I have the same Husky as that but with the Kohler engine. It is otherwise identical. Check out my findings here:
http://www.lawnmowerforum.com/mower-buying-pricing/4475-buying-new-budget-push-mower.html
Many of my observations will apply to the model you are looking at. I list some other options and ideas in this thread here:
http://www.lawnmowerforum.com/mower-buying-pricing/4664-looking-quality-walk-behind.html
If you need self-propelled, rwd is probably preferable and I would look at the lawnboy 10605 in that price range. This model has a blade brake function which most people find very handy.
This particular Craftsman is made by Husqvarna and is recommended by Consumer Reports. It has the B&S flathead engine and is RWD. Sears sales fluctuate frequently. Current price is pretty standard but it has been as low as $245. Sears is putting some mowers on closeout beginning Monday supposedly so it may or may not go down in price then.
First question is whether self-propelled or push mower is a better choice for you. In my case, a small yard with lots of obstacles made a push mower the best option. Having to maneuver around so much, pulling the mower backwards frequently would make the self-propelled a lot harder work for me for the size of lawn. If you are at 1/4 acre or higher, a self-propelled starts making more sense. Once you decide on self-propelled or push, then you can start narrowing your choices.
