Help finding the correct Crankshaft for my Honda HRX2174VLA
Fish
  • / Help finding the correct Crankshaft for my Honda HRX2174VLA
I would rather cut the shaft, you will be replacing the seal anyway.
It may come off just fine.
Take a lot of photos of the work, it may come in handy when re-assembling.
I didn't think about possibly cutting the shaft. Hopefully it'll come off just fine. I wasn't planning on replacing the seal as long as I don't damage it during disassembly. Is is recommended I go ahead a replace it?
I have been taking lots of pics so far.
Scrubcadet10
Moderator
Staff member
Yes, replace the seal.. Don't want to have to pull the engine a 2nd time to do it in possibly a few weeks days or weeks.
Fish
Yeah, you are replacing the crank, if the pan won't come off easily, don't force it, or you will damage the "bearing", and need a new pan.
The seal should be replaced anyway.
Alright so some bad news, I was able to get the flywheel off today but it looks like the woodruff key half sheared and damaged the channel on the flywheel. So I'll need a new flywheel and woodruff key. :cautious: I'm finding conflicting information again on which part number flywheel I need. Which part number matches my machine? 31105-Z0Y-N51 or 31105-Z0Y-922?
Scrubcadet10
Moderator
Staff member
Looks like 31105-Z0Y-922 is listed in the diagram for the serial number range of your mower.
Chris Parman
I would say the 31105-Z0Y-922 part number from Boats.net. Screen Shot 2020-08-07 at 1.11.05 PM.png
jobatt5
So I am pretty lost. I need to replace the crankshaft because its bent. I can not for the life of me find any supplier that has a motor matching the one on my Honda HRX mower. Here are all the SN/Model numbers I could find on my mower.
Mower:
Model: HRX2174VLA
Serial No: MAGA - 2284609
Engine:
Model: GCV190
Serial No: GJAAA 2861903
Additional Sticker on Engine: GCV190A MX5 R280
Extra bit of info I found while researching: I'm pretty sure this mower is also listed as HRX217K4 VLAA on some websites, but like I said I've had no luck matching my exact engine. I found two possible cranks for my engine but can't tell which one I actually need. I think its between these two part numbers 13310-Z8D-610 and 13311-Z8D-900.
Links from my research:
I'll also attach pics of the serial and model number stickers in case I am missing something.
Can anyone help me figure out what part no. crankshaft I need? Thanks!
View attachment 53488View attachment 53489View attachment 53490View attachment 53491View attachment 53492View attachment 53493
Go to PartsTree.com they are great.
