denthefish
- Apr 21, 2017
- 3
- 11
Hi new here --- I have a 2000ish DYT 4000 18.5 intek - It will run about 10 minutes just fine - then starts to sputter almost stall and puffs white smoke like an Indian smoke signal ---- flipping the throttle up and down I can get it to run but will happen again and again -- I can let it idle all day - no issues - I replaced the head gasket --- maybe I adjusted the valves wrong -- HELP ! once it gets hot it will not start - 1/2 hour later it will start fine
