Hello
L0bsang
G’day all,
New here, from the Northern Rivers in NSW. I fix mowers and small engines for people around the area, and I’ve ended up on a job that’s got me scratching my head a bit, so figured it was time to join.
It’s a Toro TimeCutter zero turn with a Kohler 7000 KT725 (spec PS-KT725-3102). Someone had a go at it before me. When I got there the throttle linkage was hooked up wrong and the owner had found a spring lying on the ground. Sorted the linkage, but now it revs way too high and the governor isn’t doing its job.
What I’ve found so far: the governor cross shaft has about 8mm of in-and-out play, so I reckon the retaining ring is missing. I also did the static adjustment the wrong way round (turned it clockwise when the Kohler manual says counterclockwise). The plan is to fit a new ring, set the end play, and redo the adjustment properly. If anyone’s been down this road before with a 7000 series, I’d love to hear how it went, especially if it ended up being something inside.
I’ll post up the full details with photos once I can.
Cheers,
