Hello to Everyone
bankercop
Engine Runs too Fast
I'm a new member and an acknowledged novice at mower maintenance and repair. Recently I replaced the diaphram (fuel pump) on my son's walk-behind Rolens mower which has a 4.5 hp Briggs engine. It wouldn't run at all before but now runs at an extremely high speed. I suspect that it is a governor problem but I don't know much about how the governor works so I wondered if someone out there could give me some advice.
bankercop
Thanks for your help! I took a look at the linkage and spring and found that the assembly was incorrectly installed and the spring was pulling in the same direction instead of opposing the governor as it should have. It worked perfectly when I changed the direction of the spring pull.
