Hello All! First post to this forum. I'm working on (rebuilding my first engine) a 19.5 HP B&S Intek single, vertical, OHV engine due to a shattered connecting rod.
31P677
0804-B1
080402ZE
Q: I'm reusing piston, however I'm installing new rings...should I use a dingle ball hone (if so which and where to purchase) or a regular 3-bar stone hone?
I plan on using WD-40 in cylinder while honing.
Q: How, or best way to clean cylinder after honing?
Q: Regarding ring gap placement, I know to stagger each ring gap...should any of the ring gaps lie above either wrist pin opening or does it matter?
Thanks in advance.
Keith
31P677
0804-B1
080402ZE
Thanks in advance.
Keith
