philsphanatic
- May 21, 2020
- Threads
- 1
- 2
Hello all, long time reader, 1st time poster
I have been doing tons of research on ZTR's to utilize on my own 2 acre fairly wide open property, as well as 3 or 4 other 1+ acre yards I will be cutting pretty regularly. This may grow into something more permanent/professional in the future. I am just outside of Philly in the burbs, mostly KBG and TTTF lawns. My own lawn is always soft, very high water table, probably putting close to 500ft of French drains in later this summer.
Because of the wet and soft, I have tried to find the lightest ZTR's with the widest tires for low PSI on the ground while still getting somewhat commercial build quality. This has led me to the following contenders, I am looking for opinions on 1. comfort for a larger operator, I am 6'2", 300Lb. 2. Cut Quality on these northern grasses, not a full time operator so I will generally be able to avoid wet grass, not necessarily wet/soft soil. 3. Durability/Ease of maintenance. 4. Bang for the buck.
The contenders w/ current quotes:
Scag Patriot - 61" 25hp Kohler Command Pro, regular non velocity+ Deck, ZT3400's, 10mph, 952lb, 24x12x12 tires, 3yr 500hr warranty - $6600+tax (would have to add hitch)
*Like that it has a gas gauge and a brake pedal, no floor flip access to spindles, gas tank mounted high on side, wasn't a huge fan of deck adjust set up, very little info on the cut performance of this deck.
Kubota Z421 - 60" 23.5hp Kawi FS730V, ZT3600's, 10mph, 904lb, 24x12x14 tires, 4yr 500hr warranty - $6550+tax (Can add full suspension seat for about $500)
*Like the very low and wide stance, brake setup and cockpit storage/features, low profile tires may ride rough, any reason to be concerned about FS Kawi, not sure about cut quality other than a couple reviews that say its good.
Deere Z740R - 54" or 60" 23.5hp Kawi FX730V, HC Pro (9Iron) Deck, ZT3400's, 10mph, 1046lb-1076lb, 24x12x12 tires or tweels for $800, 4yr 1000hr all Deere warranty - $8000+tax for 54" regular tires
*Like the handle integrated parking break and full suspension seat, love the option of 54" still with the wide tires, don't like how high up you sit, tweel option is a plus, will the HC Pro give the same legendary cut quality as the 7iron Pro?
Toro Z-Master 2000 74492- 60" 24.5 Toro 708cc commercial, TurboForce Deck, ZT3400's, 10mph, 920lb, 24x12x12 tires, 4yr 750hr all toro warranty (Extendable to 5yr with maint kit purchase) - $6700+tax or $7200 for the same unit with FX730v
*concerned about toro motor quality and small displacement, but 5yr warranty is very nice, not a huge fan of deck adjust or parking brake.
Toro Z-Master 2000 HDX w/ MyRide 74494 - 60" 24.5 Toro 708cc commercial, TurboForce Deck, ZT3800's, 11mph, 1036lb, 24x12x12 tires, 4yr 750hr all toro warranty (Extendable to 5yr with maint kit) - $7800+tax
*Same as above but love the idea of the MyRide assuming my weight doesn't overwhelm it.
Looking to make a decision in the next two weeks, finding it very difficult to get demos on the not quite full commercial units. The Kubota/Toro dealer is less than 5 min from my house, Scag is 10min, Deere is 20min, reputation is good at all of them but I have no personal experience.
Open to other options, but needs to be around 1000lb with 12" wide tires, all of these units have the same size front casters.
