Mulching Hard time locating mulching plug/kit
ARMYtango
Hey all..
I have been having a hard time trying to find a chute plug...or mulching kit....for my Snapper Pro 50XT zero turn.
Anyone have any leads as to where I can purchase one?
I understand that my Snapper dealer may be able to get one, but they are a little higher priced in their products, so I would like to look online to see if I can find anything else a little cheaper.
I just really need the plug, but I will consider purchasing the kit if I need to.
Thanks all!
ARMYtango
Still looking!
Anyone with any ideas?
thanks!
Carscw
I have looked and can not find one.
ARMYtango
Unfortunately, I think Snapper discontinued them. :frown:
Not sure why when they still sell the same model mower.
Just hoping that someone else out there may have a kit kicking around that they may want to get rid of...
ARMYtango
UPDATE:
I did find one that seems that it may work...
Simplicity 1696421YP.
I decided to search for Simplicity since it is the same at Snapper.
And no matter where I look, they all seem to be $239. :eek:
Pretty steep for what you get in my opinion, but hey, as long as it does it's job....
A couple of short lengths of wide steel strip. a drill , a file & 4 cup headed bolts.
If you want to remove it easily use wing nuts with a thick O ring under them to stop them vibrating off.
Carscw
A couple of short lengths of wide steel strip. a drill , a file & 4 cup headed bolts. If you want to remove it easily use wing nuts with a thick O ring under them to stop them vibrating off.
A lot cheaper and just as good.
ARMYtango
hmm...that is a good idea...
Just wish i had the ability...and time...to make something like that...lol
Thank you
