I have a wonderful low-mileage one year old HRR216PKA that has been perfect until last week. The first two uses this spring were uneventful. Last week I tried to start it and it would not fire. Oil was okay. I checked the gas and it was low so I had topped it off. Then I noticed that the fuel valve was off. I turned it on and tried again to start it - it still did not fire. I tried off and on for almost an hour to no avail. Finally I gave it one last pull, this time a little harder and it fired right up. It ran and sounded normal. I stopped it a couple times and it easily re-started. I finished my trimming and put it away in the dry-as-a-bone shed.
Today I went to use it for its usual 20 minute trim duties and again it would not fire. I removed the air filter (clean) and gave a quick shot of Sea Foam Spray into the carburetor. One pull and it fired and ran fine. Again stopping and re-starting presented no further problems.
It has never been abused. I use mid-grade Shell gasoline and always use Sea Foam to treat it. The spark seems to be normal. What can I do that will not jeopardize my warranty? I have a great dealer but I am retired and on a tight budget. The mower's duties are trimming around gardens and fence lines - about 20 minutes of use weekly.
I suspect it might be carburetor/choke related, but other than removing the air filter element I have not delved deeper.
Any thoughts?
Any thoughts?
