h4514 Throttle cable 17910-758-010
rothomas
I am in need of a throttle cable for an H4514 part number 17910-758-010. It appears that Honda is no longer making it and with out a replacent the LAwn Tractor is not going to able to run this year. Can anyone help?????
mechanic mark
Carefully remove you old one
Search "control cables manufacturers "
There are hundreds of them, usually found near light air craft airports because they use cables to control the aeroplanes
Usually they will be able to make a new one or just replace the inner .
I get a local to do them for me usually $ 10 to $ 20 as comparred to $ 60 to $ 200 depending upon the mower brand .
And he uses a lot stronger cable to boot .
