AVB
- Dec 13, 2019
- 200
When come small engine the term magneto usually refers to ignition coil. What is call an alternator is the stator coil and the flywheel internal magnets. Si if you are to the spinning flywheel then it creates an AC voltage and current which is converted by diodes into DC then feed through a voltage regulator then to rest of the circuit.
