GX270 Won't turn off
johns6
I have a Honda GX 270 that runs perfect except that it will not turn off using the on and off switch. The switch tests good and I even went so far to replace it. I am now stopping the engine by choking the carb. Engine starts on first pull whether switch is in on or off position. Any ideas?
johns6
The engine is on a Northstar (Northern Tool) 37 Ton Log splitter 2009 model. The engine, a Honda GX 270 is the problem.
reynoldston
Don't know how the throttle linkage is set up on your log splitter but the engine turns off by grounding the coil primary wire. Small wire that goes to the coil.
johns6
Found a broken wire coming off the coil, problem solved.
