Hammermechanicman
- Jan 10, 2020
- Threads
- 69
- 3,919
Grasping at straws here. Make sure whatever is attached to the end if the crankshaft is tight. I have seen mowers with a loose blade kick back.
When the plug is removed, there is 0 compression. To truly test without the plug, use a compression tester in place of the plug. That way you get compression and a reading of how much.I wondered that myself but if I disconnect the spark plug, I can pull it over all day without any kickback. As soon as I reconnect the plug, it kicks back when I try to start it. That points me back to a timing issue.
Have a close look at the exhaust for black smoke and check the plug for soot.
If the spark is too late then you get a build up of soot on the plug & exhaust valve .
