guys, i'm not getting a smooth cut. any idea why? raptor sd 54
No concerns with your warranty by cutting the deck open?
Did you notice a substantial difference in discharge after you cut it?
well i doubt i'll ever have a structural warranty issue with the deck. and you cant tell i even cut it out.
the outlet does not get plugged up easy in tall wet grass, like it did before.
Interesting.
Our supplier exclaimed, and I mean "exclaimed"..."put a spanner on it and yer done, WE cannot
mod without authorisation from the manufacturer". This only very shortly after delivery and with
a relatively minor (faulty) component which could be easily rectified. It took some 'testing' and
RTD's to get the problem sorted. End cost to us was four times the value of the mod which was
eventually fitted.
Warranty is often more about generating income more so then true user satsfaction...IME
I digress...
It is not unusual to have to do two cuts at two heights on the style of "weed" talked about here.
And the further it can be thrown the thinner it gets for the next cut. The more cuts the finer
the mulch, with a resulting faster "meltdown" period between mows.
It is all about choices with operator savvy being the prime factor. Live and learn in other instances.
That's me tapped out....
KK
/out
