so i went back to finish up today. this parcel of land is probably 3+ acres. i thought the hustler literature said you can mow over 3 acres an hour :confused2: it took me probably a total of 8 hours.
i had to go slow somewhat and cut it twice to look decent.
my old lawn tractor broke and i waited a while for my dealer to get one of these raptors in stock, so that is why these weeds got so tall. i'll be cutting more frequently.
anyways a little about the blades. the stock blades are horrible in tall grass. there just isnt much lift and suction/blowing with them. the deck constantly plugged up and got packed with grass. i tried a set of the high lift blades (hustler# 797696) and they did ok. but then i tried the oregon 596-808 blades and they worked the best. they threw the grass the farthest out the shoot and kept the deck cleanest.
i did cut the deck outlet bigger, which helped a lot to prevent the outlet from getting plugged up. the opening is rather small compared to other decks. i'm not sure why the back edge of the opening is angled but it caught a lot of grass and the whole outlet would get plugged up solid with grass.
