N Noelbrmr Forum Newbie Joined Mar 12, 2016 Messages 1 Mar 13, 2016 #1 ANY TIPS ON CLUTCH REMOVAL/REPLACEMENT? IS IT PRETTY STRAIGHTFORWARD?
M mechanic mark Lawn Pro Community Leader Joined Jul 15, 2013 Messages 7,499 Mar 13, 2016 #2 Absolutely yes, just be sure to remove negative battery cable for Safety First.
B bertsmobile1 Lawn Royalty Joined Nov 29, 2014 Messages 24,995 Mar 14, 2016 #3 And keep your head out of the way. They are heavy , sometimes drop right off and are difficult to balance on your nose :laughing:
Glyn Robinson Well-Known Member Joined Jun 17, 2015 Messages 246 Mar 19, 2016 #4 took mine off today and greased the bearings with a hypodermic needle. they make a slight noise when the pto is off. they quieten down when i turn the pto on. so, i hope to buy a little more time.
BlazNT Lawn Pro Joined Apr 26, 2012 Messages 6,973 Mar 19, 2016 #5 Once they start making noise its to late to save them. It will break very soon same as if no oil added. It will just be quieter about it.
Glyn Robinson Well-Known Member Joined Jun 17, 2015 Messages 246 Mar 20, 2016 #6 i'm sure i'll be buying one at some point. hopefully it will be awhile because i don't have much yard to cut.
