I have a 2014 729T. It has 2 pillow block bearings ( 2 zerks) on the drive shaft.
I got mind greased. Had to change zert. Put a straight one on. Thanks for the help. Cambre
Those carrier bearing fittings are accessible from underneath. It's a pain to get at 'em, but as an earlier poster wisely advised, don't let them go. The carrier bearings are much harder to replace than they are to grease.
If the factory parts bin was still full of zerk- fitted ?housings? they would continue to use them even with sealed bearings until used up, I think.
Dont be afraid to ask for help. I'm on my 5th Grasshopper and know a thing or 2 about them.Thanks for your help.
No need to take the gaurd off, its right there!
