NEED SOME EXPERTISE!!!!
This Kohler has been running just fine with zero issues for years; recently as I was mowing, obviously blades engaged, the mower acted as if I pulled the throttle back to idle; it would not throttle up after that. In idle, I drove it back into the garage, shut it off ... and now it will not start. It cranks normal, and busts off but just as if I was trying to start it in idle; if I choke it, it will bust off, but not start or run.
Things I have checked:
> Anything obvious such as damage, anything loose, stuck, cracked etc...
> Fuel level (same fuel I've mowed with for the past 3 weeks)
> Fuel flow (Replaced Fuel Pump and Inline Filter) (Removed Fuel Selector and verified correct working order) Fuel getting through pump, into carb...
> Checked for cracked fuel lines or loose connections
> Oil Level (checked for Oil Level Switch) apparently this model does not have one.
> Kitted the carburetor (same reaction, no difference)
> Every safety switch I can find (they seem to be in order)??
> Replaced Spark Plug
> Checked for good spark (yellow/blue)?? Not the best I've ever seen, but not the worst either
> Checked all fuses that I can locate
> Checked the carb solenoid (does not work, hasn't worked for the entire year, removed needle) Has worked just fine until that moment / But???
Here's something I've noticed while trying to start it ... if I choke it, it tries to start but will not. move the throttle to med-high, it will not try to start until I choke it again.
Any help or thoughts would be greatly appreciated ...
> Replaced Spark Plug
