Robert Jordan
I have a Gravely ZTR 60. The right hydro gear will not pull at low RPMs and when cutting at max RPM the right gear wines, jerks and stop pulling when making a turn or pulling out of a ditch.
Model 991166 SN O15581 I changed the oil and filter, two quarts plus pre filling the filter. A passer by said he thinks the handel you pull to push the mower by hand has a weak spring and allowing oil to by pass.model no. and serial no. could be low on fluid
Follow the hydro bypass rod back to the hydro transaxle and look at it and push/pull it back and forth and see if it has full travel. Check the other side for comparison if needed. Make sure no debris is blocking free travel of bypass rod.Model 991166 SN O15581 I changed the oil and filter, two quarts plus pre filling the filter. A passer by said he thinks the handel you pull to push the mower by hand has a weak spring and allowing oil to by pass.
Kinda doubt it if the condition existed before the bypass was engaged.Follow the hydro bypass rod back to the hydro transaxle and look at it and push/pull it back and forth and see if it has full travel. Check the other side for comparison if needed. Make sure no debris is blocking free travel of bypass rod.
