Well and this is important. Are you doing the standard leakdown test or the modified one that I use on OHV engines? The modified test can check the whole cylinder stroke as a standard test only checks the upper cylinder. Cylinders tends to wear both oval and taper in the lower cylinder. I had engine that pass the standard test but fail the modified test.That's the odd thing. The leak down test indicated it was in good shape.
