bit late for you now.
You start by checking the control ( trigger ) wires that go on the base of the solenoid
If there are 2 of them , 1 should go + 12 V with the key in the start position, the other should be ground in the start position.
In some systems, both are switched
Typical on ZTR the + wire will go through the PTO & brake switches
While the ground will go through the lap bars.
To make assembly easier most switches are double pole so have both a 12 V switch for the starter & ground switch for the kill wire.
Cross them over , send 12V to the magneto & you will kill them stone dead so it is prudent to disconnect the kill wires from the coils before you start then remove the spark plugs
Cranking circuit
Hot wire on solenoid
Fuse
B terminal in ign switch
S terminal in ign switch
PTO Switch
Brake switch
Solenoid trigger wire
After you have checked the ignition switch is connecting the B & S terminals, pull the plug off the back of it and bridge the S & B wires.
Switch will have the letters B, S, G, M , A & L cast on the back
In the start position B & A are also connected which will turn on the fuel solenoid and you dont want that to happen sa the fuel solenoid needs fuel passing across it to keep it cool so you have to make sure you are only bridging the B & S
